주요 콘텐츠로 건너뛰기
모델 A1369, 1.6, 1.7, or 1.8 GHz 프로세서, 64, 128 또는 256GB 플래시 저장공간
328 질문 전체 보기
How long is a new battery's shelf life?
The battery in my 2011 Macbook Air began raising a "replace immediately" alert after 2.5 years of age. I ordered a new one, and waited for the old battery's charge to degrade, but it never did. That was over a year ago. It can still last for about two hours on a full charge. In the meantime, the ifixit battery I bought is still sitting on the shelf in its shipping box. While I continue to wait, is there any danger of the new battery getting "stale" and not working well when I finally do swap it in?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 2개
가장 유용한 답변
Hello,
from my experience the degradation of a battery life depends on the discharge/charging cycles. So if you leave the battery in its package on the shelf for a long time the chemical reactivity of the single battery cells should remain at a very high level. Although the battery could loose some voltage after some time.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I've exactly the same question, but my MBP 2009 Model still holds a charge of 2-3 hours. I've got a new battery sitting in my shelf since OS X keeps telling me to replace it, but I don't want to replace it until the old one inside the MBP has been completely used out.
Did you find any answer to your question?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
johnsgchurchill 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 847
