Volume indicator indicates bacwards
Volume indicator starts at 60 (no volume) and counts backwards to 1 (full volume) What do I do to fix the problem? Or is there some good reason as to why the volume is indicated this way?
좋은 질문 입니까?
좋은 질문 입니까?
From the units I've seen, home receivers are just set up that way. I'm sure someone will have a better answer after me. If you look carefully, it will probably be a negative 60, rather than positive. That's the experience I've had, anyway.
Basically, each decibal is a ten-fold increase in sound. If no sound was labeled as zero, ten times that would still be zero. So the loudest volume is used as a reference instead.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,699
