Why won't my Lenovo A7-40 power on?
it was fully charged n it just stopped working and wont on
its been 3 days and it wont get on i tried charging it but it wont get charged
좋은 질문 입니까?
좋은 질문 입니까?
Guys Just press reset button and then press power button..if you cant find the reset button just open the back cover en then you can press it with finger... Good luck
해당 답변은 도움이 되었습니까?
I had such a problem
The battery just had been moved
I put it right and labeled it
It worked
해당 답변은 도움이 되었습니까?
If you can feel the motor is buzzing, try to check the lcd cable, many lcd cable faulty in this device, that`s my experience, or try to disconnect and put it back. If it`s not charging can be charging port issue or battery even motherboard. try to factory reset with the power button and the volume up button.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 3,343
댓글 3개
I have a tablet and it turns on and you can hear everything but you can't see anything
Nicholas 의
I have this problem
playingsafeps 의
my lenovo won t open
wildalachica 의
