Why doesn't my touch screen respond?
tounch screen of my mobile htc 816 does not work. I bought my mobile from 3 weeks and I do not know the problem come from
Please help me to find the prolem if it is hardware or software
좋은 질문입니까?
좋은 질문입니까?
A soft or hard reset may fix this problem if it is software related.
To do a soft reset:
If the display is off, press the POWER button to turn it back on.
If you've set up a lock screen, you need to unlock it.
Press and hold the POWER button, and then tap Restart.
When asked to confirm, tap Restart.
If it does not respond when you touch the screen or press the buttons, you can still restart it. Press and hold the POWER and VOLUME UP buttons for at least 10 seconds. It should now restart.
Be sure to back up any data and files you want to keep before you do a factory reset.
To do a hard/factory reset:
Press and hold the VOLUME DOWN button, and then press and hold the POWER button.
Wait for the screen with the three Android images to appear, and then release the POWER and VOLUME DOWN buttons.
Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
Your phone should be set back to factory setting now.
If resetting doesn't get your touch screen responsive then you might have a faulty digitizer or a loose or broken digitizer ribbon cable or connector on the motherboard. The digitizer part of the screen is responsible for sensing touch. If you find fault in the cable you will need to replace the digitizer.
이 답변이 도움이 되었나요?
Superb and thanks dude...Please dont buy this mobile anyone this is very hectic and functionality is very bad.
thnku for the suggestion...
worst phone ever!
I've repaired the LCD + Digitizer with Frame a lot for many customers. Not a single one have come to me about this issue. If your system software is not up to date. I recommend to update it to the latest available update.
The digitizer connection shouldn't get loose. It's held around with grey adhesive tape making it pretty hard for it to come unplugged or loose by itself. Though the other flex cable connecting the digitizer cable to the logic board can become loose in some cases, It has foam behind the cable where it plugs into the logic board.
thanx a lot my friend it worked
tap the screen with a hammer as hard as you can
이 답변이 도움이 되었나요?
my touch screen not working properly htc desire 526. very disappointed with this phone.
Lol don't listen to the guy above unless your fed up like me I may take his advice but before we smash our phones try updating software first
my HTC desire 816W has same problem.open automaticaly programs,and now left side of touchscreen is disabled.display is OK.but touch has problem.what is the solution?
이 답변이 도움이 되었나요?
How can you go to setting and then recalibrate on something that is not responding to touch Raguraman?
이 답변이 도움이 되었나요?
No it is not a hardware issue it's a software issue I also feel this issue after updating the latest software of HTC desire 816
이 답변이 도움이 되었나요?
what software version may solve the issue?
I also had this problem for quite a while. My phone does give me a headache because I can't always use it (I am getting a new samsung this June) but I have found a solution that works for me. What you have to do is create electricity for the screen. To do this, you create static electricity but rubbing your hand roughly against the screen until it feels very hot and it gets harder for your hand to slide across. This isn't permanent, and you might have to do it every time you pick up your phone, but it works.
이 답변이 도움이 되었나요?
Just switch of the phone and restart if it is not working go to setting and calibrate
이 답변이 도움이 되었나요?
It worked for me . Great thanks
there should be problem in hardware n software to...first let me help with software issue if your touch is not responding swicth on the cell phone and only press switch on button for a long time and after pressing 1-2 minutes u r phone will be restart.....than it problem will be solved.....if it doesnt than open the cell phone and remove the touch pad there should be a moisture clean that and definetly it work..........**** if u like my answer best of luck
이 답변이 도움이 되었나요?
이 답변이 도움이 되었나요?
And what happens when I press the hard reset buttons and it does not work
이 답변이 도움이 되었나요?
I know one %#*@ solution
If you recently changed your screen ,
Keep your screen cool (don't use it in hot surrounding) (like put it in front of air conditionar for few minutes and boom your screen works fine )..it becomes unresponsive when screen gets heated ….its an hardware issue not an touchscreen or software issue ..I have conformed it by myself
이 답변이 도움이 되었나요?
I have this problem as well but with the HTC U11. I already changed the screen and even with the new screen the touch is unresponsive. Does anyone know what may be the problem, or how I could fix this?
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 10
지난 30일: 24
전체 시간: 66,079
댓글 7개
me also same problam -htc desire 816 i got before 3 weeks but noe touch screen not working - i am reset the phone also but no sucess. i have to go to seller now
nandana88c 의 공유
My htc also same probelm my screen not working properly
Raguraman 의 공유
my mobile also as like ur problem now what can i do plz suggest me
basha shaik 의 공유
Wow I thought I was only having trouble my HTC desire is not working my screen is fine but no response it sounds more software but let's not leave The hardware out yet until we know sounds like HTC software
Rodney meece 의 공유
My HTC Desire 820ts touch is showing problems like if sometimes it does not respond . And also when I tap on one application , it goes to another . Please can you help me ?
Mubin Ahmed 의 공유
댓글 2개 더보기
