주요 콘텐츠로 건너뛰기
Samsung의 5-세대 Android-기반 Galaxy 스마트폰은 2014년 4월 11일에 출시되었습니다. 이 휴대폰은 지문 스캐너, 최신 카메라, 대형 화면 및 방수 기능이 개선되었습니다. 네 가지 색상으로 제공됩니다; 검정, 파랑, 흰색 및 구리.
577 질문 전체 보기
Why can't I see my texts I'm sending
I type in my text message and hit send and it disappears and does not show on the screen but the recipient gets it, can you tell me what's wrong?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 11
댓글 9개
I'm having the same problem. Also when this started I also lost my emotions
My phone just started doing the same thig today - I do not use my phone allot - i have hardly any apps- my phone was on the night stand, it says i have 5 new text messages and the nothing shows up. Also when i send a text message it just dispears and the privious text that was sent to me glitches or moves and then my disappears - I called my friend to confirm they recieved my text and they are but i cant see anything. ?
Me to just started doing it today.
I also have the same problem. My Samsung J2 (2016) sents SMS but there is no record where it has been sent. It keeps on sending as and when it desires. I am unable to find what message and to whom it was sent.
H.P.Agrawal
My phone went dead after a restart and when I was able to get it powered on I had the same problem.. I couldn't see my own messages going out but they were being received. I reset the date and time to my network (just turning on WiFi) and it fixed the text messaging problem. Hopefully mt fix will be as easy as all of yours, cheers.
댓글 4개 더보기
댓글 달기
답변 8개
가장 유용한 답변
fix your time or your time zone that will take care of the problem
해당 답변은 도움이 되었습니까?
점수 12
댓글 11개:
good job!!! worked for me. thank you
that's another thing my time zone changes automatically - i have had to change several different times.
I had to uncheck Automatic Time Zone and choose it manually. WORKED!! :) Much appreciated.
thanks! that worked!
It worked for me too! Each time I sent a text it would show the very last text not the one I'd typed but now it's working perfectly now I set the time manually. Thanks so much! xxx
댓글 6개 더보기
댓글 달기
Switch from Samsung's message app to Google's Messages app.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
Try asking Samsung or your Provider. This is not a hardware-related question.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
turn your phone off and on...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Try putting your texting back to original. Or default reset
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
If time is not set to automatic update date and time it will do this .Go into setting date and time and check auto update should fix it
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
It's just started happening in my phone that I just brought 3 days ago. Time is wrong and I cant see all the text messages ive sent. I can only see them sent to some contacts and not others even though the ones I cant see have said they've recieved them. Getting rid of this phone.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
You may want to uncheck auto time update
댓글 달기
이미지 내용 보기:
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
burrichter237 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 26
30일 전: 99
전체 시간: 48,125
