주요 콘텐츠로 건너뛰기
The Asus MeMO Pad 10 features a vibrant IPS display with a 1280 x 800 resolution.
Asus MeMO Pad 10 won't power on?
I have a MeMo tablet that won't turn on. It does charge (the LED will turn green after awhile). I've tried all the various button-holding suggestions, poking the reset button, opening it up and leaving the battery unplugged for a time, and even swapping the battery with a known good one (I have two of these), but nothing has made any difference. The device was working fine, and then suddenly just stopped. It was not dropped or bumped recently. Any suggestions?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 10
댓글 2개:
How do you open the tablet up to replace the battery?
i get no charge even
댓글 달기
답변 1개
If you search around there's a youtube video that will show you how to do it. The main shell comes apart by prying the back off with a thin blade. Then you have to disconnect one multi-pin cable, and take out a few screws to free the battery, but it's not too bad. No glue!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
ifixgrax 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 3,267
