주요 콘텐츠로 건너뛰기
2012년 6월 출시 / Core i7 프로세서 Turbo Boost 포함 / 최대 1 GB DDR5 비디오 RAM
596 질문 전체 보기
질문 마감됨
2012 MacBook Pro 15 shows no sign of life after touchpad swap
After following a guide on this website, I switched out my malfunctioning touchpad with a new one. Everything went fine, no forcing, no damage, all ribbon cables are fine etc. But, once put back together, it shows no signs of life. The power button gets no response. They battery indicator lights on the side show no response. The magsafe adapter doesn't even light up when plugged in. I have tried the SMC reset but that has gotten no response either.
Any suggestions? I can take it to the Apple store, but I would rather avoid the cost/embarrassment if possible.
Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Double check the keyboard ribbon cable is fully inserted and you opened and closed the latch correctly. Try using a small piece of electricians tape to help pull the cable into place.
The only other thing I can think off is ESD. Did you use a ESD mat & wrist strap which was properly grounded? During the winter and early spring the air is quite dry so static is a big problem. It doesn't take much to kill a system.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 93
