주요 콘텐츠로 건너뛰기
A 10-megapixel, point-and-shoot camera developed by Canon in 2010.
Why aren't my pictures transferring to my computer?
When I plug the cable into my computer from my camera, nothing loads on my computer that allows me to transfer the images. It accepts USBs and has never had a problem before. What could I do to solve this problem?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
  • Check the cable. It may be loose.
  • The auto power may be active. This will turn the camera off while it's not in use.
  • Compatibility may be a factor. Check the file type or try another computer.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Most likely, it's that the cable is loose so just make sure it's fully connected. If that's not helping you, switch the setting off from auto power or make sure your computer is compatible with the device.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Nathan Meuwissen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 332
