주요 콘텐츠로 건너뛰기
The drone is a Wi-Fi capable and it's equipped with a built-in HD camera. It is used for taking pictures and filming. Model number: PF722000
35 질문 전체 보기
Blinking green light why?
Had a sudden loss of power or signal with drone it fell and broke cross section. Can't connect wirelessly or via usb. Just getting blinking green light which usually means motors out.
Any way stripped it a little and found white motor power plug completely disconnected. Unsure if this occurred on impact or worked loose causing motor stall.
Great thinks I. An easy job. Puts connector back firmly in place and checks all gold antenna connectors are seated and in situ.
Puts it back together and its the same. Giving off no wifi signal to connect to for diagnostic tests on motors.
Any one any clues? Could mainboard be toast.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 8
댓글 16개
Is it normal to be unable to connect via wifi or pick up the drone via a pc to usb connection with the drone when a motor failure occurs. Someone must have experienced similar issues. I understand diagnostics tells you if a motor is not running correctly but I can't connect so unable to diagnose issue. It did come down on one motor strut which I assume then sent the energy into the cross section which fractured.
i have the same problem, green LED light keeps blinking
Hi I was told to disconnect all motors and see if that brings it back to life if it does then a motors broken. It didn't work for me.
Mine was a shorted mainboard. I sent it off for repair and after a reflash it came back to life, the fan was replaced and a motor and cross section replaced. Whole lot cost me £80 Gbp.
Hi stu where did you send it for repair I have the same issue
Southend on sea in Essex. Was given guys details by Parrot. Are you UK based dan.? I can't put his email on here because of spammers. Basically the guy charges £15 for diagnosis of the problem and that includes return postage in the UK. If your happy with him proproceeding he gives you a price and if your ok with that you paypal him money and he proceeds. Alot cheaper than buying a whole mainboard if its an individual component out on the board. Heres there website. Use contact us section. http://custemz.uk/
댓글 11개 더보기
댓글 달기
답변 4개
가장 유용한 답변
read on forum that i might be your camera, disconnected or damaged cameras will give the green light flash.
let us know if this helped
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
thank you this worked :)
if you don't mind me asking where did you find your information for this?
why would this be a problem my lens is broken camera is not but im getting green flashing light can anyone help ?
hey david,,, so if my camera is damaged and disconnectng it wil also giv blinking green light, so then i have to buy another camera for it to fly? i cant jus disconnect it?? what else causes the blinking green???
댓글 달기
This problem has happened to me so.i just took off the nose cone. Checked the GPS Tab to insure the Connection is tight. Made sure that the tab wasn't resting next to that tiny resistor. Put the battery on without the nose cone and it fired up correctly no more flashing lights. Took it Flying afterwards
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
We have a Sky Tracker gps video drone . We have tried calibrating it and the lights won't quit flashing . We have tried everything . Any ideas ? . And is there suppose to be a little line that is white ( almost transparent ) suppose to be sticking out ? Hope someone can help .
댓글 달기
This was the final correspondence between Parrot and myself regarding my parrot bebop that never flew-
Hello Parrot thank you for the excellent technical support !  I received your trouble shooting document and followed it.  I also did some of my own troubleshooting, which included measuring the charge voltage on both batteries. Unfortunately nothing worked (Power light button only flashes green- no wifi connection- no fans- no power off-no reset-nothing else). According to your trouble shooting document along with Bebop forums on the internet the final solution was to send the Bebop back to your factory for additional refurbishment. The Ebay seller already has it back in their possession and has sent out a replacement Bebop to me. Once again I really would like to thank you for the excellent support and I look forward to my first Bebop flight with great anticipation : )
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
same problem on my bebop after crash then flashing green ligth occur. i am lucky that i find this session so i know what yould i do.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
stu 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 17
30일 전: 51
전체 시간: 18,938
