주요 콘텐츠로 건너뛰기
모델 A1200 with 2.16 또는 2.33 GHz Core 2 Duo 프로세서
111 질문 전체 보기
Formatting iMac hard drive
Do these hard drives come preformated for iMacs
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
What are you upto here: Are you replacing your current drive or are you trying to get your system working? The more information you can give us the more it helps us help you.
댓글 달기
답변 1개
선택된 해법
Most drives need some level of prepping (Windows or Mac OS-X) and all need an OS installed.
Update
Sorry to hear your drive failed.
But before you get a new drive you'll need to make sure you get the correct one. Your system supports a SATA II (3.0 Gb/s) drive. Don't get one of the newer SATA III (6.0 Gb/s) drives as it worn't work reliably. You may want to consider getting a SSHD hybrid drive like Seagate's.
The next thing here is prepping the drive do you have a second Mac system or access to one? That will make things easier.
For now let us know what drive you are thinking about and if you have access to a second Mac system and what model it is.
Update
To prep up your new drive you have a few options:
The easiest is to install the drive in your iMac, then connect your MacBook Pro via FireWire cable to your iMac (back to back). Then startup your iMac in Target Mode. Once up and accessible by your MacBook Pro like an external drive you can use Disk Utility to format and setup the partition/s the way you would like to have. Then you can use the Mac OS installer application to install the OS on to the drive. Just make sure the OS you install is the correct one for your iMac.
The next option is to use an external FireWire or USB drive case (or IFIXIT universal adapter) to hold your new drive. Then connecting it to your MacBook Pro. Here you do need to be careful as the desktop drives pull a lot of power so make sure to use an auxiliary power supply as I've seen drives not correctly setup when the power was just on the edge.
해당 답변은 도움이 되었습니까?
점수 3
21 댓글:
My drive failed and I need to replace it, just do not know how to format it
2009 Apple proprietary drive? Sensor cables?
Not an issue in this system. It has a stuck on thermal sensor.
yes I also have a macbook pro. The drive I was thinking of for my iMac is Toshiba-2TB-35-SATA-60GB-s-7200-RPM-Internal-Hard-Drive.
What do I do to format it using my macbook
Sorry the Toshiba drive is a fixed SATA III (6.0 Gb/s) drive which is too fast for your system. You'll need to find a SATA II (3.0 Gb/s) drive or one that senses the systems SATA ports speed. Checkout this: Seagate desktop SSHD unlike the Toshiba drive it senses the systems SATA port speed and matches it.
16에 댓글 더 나타내기
댓글 달기
귀하의 답변을 추가하세요
Dan Spicer 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 914
