주요 콘텐츠로 건너뛰기
Fix Your Stuff
Right to Repair
Parts & Tools
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
64 질문 전체 보기
went to sleep mode, and is not switching ON
Recently, my Dell Laptop Inspiron 1545, went to sleep mode, and is not switching ON again. It is as though it died. I everything from pressing the power button for a minute continuously to removing the battery, plugging it back and then pressing the Power button
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
답변 2개
선택된 해법
The problem was due to accumulation of dust in fan area and the fan would stop, increasing the heat in system and the system was shutdown due to high heat.Just opened and cleaned it now Ola everything is fine.Thanks everybody for answering.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Last time I had someone with this problem, the charger was dead, and the battery ran dry, and that's why it wouldn't turn on.
Are you sure the charger is working?
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Also, the trick you described above would go:
1 remove battery and charger (all power sources)
2 press power button for 10-20 seconds
3 supply power again (battery and/or charger)
3 try to turn on normally
의견 추가하세요
귀하의 답변을 추가하십시오
Harsha Warrior 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 249
