주요 콘텐츠로 건너뛰기
4th Generation Apple AirPort Extreme Base Station (Model Number A1354)
18 질문 전체 보기
wan port not detecting internet provider
my airport extreme suddenly stopped working. I can get internet through the ethernet cable direct from provider modem to my computer but not through extreme. I have tried reset and factory reset with no success. The LED indicator on the WAN port indicates it is working but no provider is being detected. If this is a hardware problem does anyone know of a possible repair.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 6
댓글 2개:
What does Apples AirPort Utility tell you?
Did you get things working?
댓글 달기
답변 1개
Apple AirPort Extreme is a simple fix, it is either the antenna or the WiFi card.
if the WiFi light is on it most likely to be an antenna, you can get one off ebay for pretty cheap
here is the guide to fix replace it.
Apple AirPort Extreme Model A1354 Antenna Replacement
if you need to replace the WiFi card, here is the guide for that.
Apple AirPort Extreme Model A1354 WiFi Card Replacement
Apple AirPort Extreme Model A1354 Antenna 이미지
안내서
난이도:
운영
5 minutes
Apple AirPort Extreme Model A1354 WiFi Card 이미지
안내서
난이도:
운영
10 - 15 minutes
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
wmathie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 5
전체 시간: 1,117
