Why won't my camera turn on?
When I press the power button, nothing happens.
좋은 질문 입니까?
The simplest reason for this problem is an issue with the battery and charging system. Make sure you are using the proper USB charger and cord and they are not malfunctioning or damaged. If everything is working normally there may be an issue with your battery, which you can replace by opening the battery compartment.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 3
30일 전: 12
전체 시간: 580
댓글 1개
Mine fell down and the lens never eject
S`busiso mqapheli 의
