메인 콘텐츠로 스킵하기
Apple의 현재 소비자용 랩톱 MacBook Air 수리 안내서.
3265 질문 전체 보기
won't boot after logic & IO board replacement. What next?
I have a wine damaged MBA mid 2012. We replaced logic board and IO board, but it still won't turn on. The magsafe charger light is orange, and does't turn green after the usual time to charge. I tried resetting MMC without change. There is no noise, no light with pressing the "on" button. Nothing else is obviously damaged inside.
Update
MBA-2012-13in-LB.pdf
Attached is a photo of the logic board. It's a bit different than the 11" logicboard. I'm guessing that the two solder spots highlighted might be the debug "on switch", but wanted to confirm before attempting to short them.
Two other questions: keyboard connected or not; and charger connected or not?
Thanks
TS
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글:
We will give that a try. Is it worth flushing the keyboard with isopropyl alcohol to attempt to clean it? (assuming that it boots up with this approach)
Thanks
의 답변
You can do this, but make sure to let it dry without other components for at lest 24-48 hours, in front of a fan if possible
의 답변
The power pads for the 13 inch are located just above the keyboard terminal. http://www.insidemylaptop.com/images/Mac.... I would leave the keyboard and battery connected, but disconnect the charging cable.
의 답변
it booted up but needed the charger connected as the battery was dead. (Battery checked out ok on system check, however). I reset the SMC since it was acting a bit slow, and that worked ok, even turned on from the keyboard power button. About 10 minutes later it turned itself off. I'm charging the battery now, but it sounds like the keyboard needs to be replaced. If so, I'm looking at the $30 eBay keyboards. Any other suggestions are appreciated! Thanks.
의 답변
The power button worked? Hmm, do all of the keys work as well? Check to make sure you have sound as well as other basic features because the problem may be something other than the keyboard in this case.
의 답변
1에 댓글 더 나타내기
의견 추가하세요
1개의 답변
선택된 해법
It may very well be that your keyboard is broken, as the power button is connected to the keyboard. To see if this is actually the issue, locate the power pads on your logic board as seen in the accepted answer by oldturkey to this question Power on pads for Mid 2012 MacBook Air 11" A1465. Using pair of tweezers, touch both of the pads for several seconds with the battery and all other components in the machine. If you hear a startup sound and the machine turns on, then you know that the keyboard is damaged, and that is about a $30 repair, though you will want to set aside several hours and an uninterrupted workspace because it involves many tiny screws. You can find a replacement keyboard easily by searching on ebay for your model number. Hope this helps!
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
tpschaaf 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 205
