주요 콘텐츠로 건너뛰기
This affordable large-screen Android phone sports a 5.7-inch display and large 3,400 mAh battery.
218 질문 전체 보기
How do I fix the sound on my phone?
The media and all the ringers are all not working even though it says it isn't on silent. When I plug in the headphones, then it works and its the only way I can watch videos.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 139
댓글 23개
My speaker is not working how do I do it if u got urs to work...please... Thanks a bunch
I'm having the same problem. Did you ever get it fixed
I got the same problem
I had to install an app called SoundAbout from playstore.
When I make call people on other end can hear me but I can't hear them, volume is all the way up and when I get call it only vibrates
댓글 18개 더보기
댓글 달기
답변 2개
선택된 답변
it seems to be your main speaker (Ringer) faulty. you may have to replace it
해당 답변은 도움이 되었습니까?
점수 19
댓글 25개:
How do I do that ?
did you ever figure it out???
I replaced my speaker and it still isn't working what can I do now
Backup all data and reset the phone. check whether speaker back to working condition, otherwise you have to check audio out/ amp section carefully
댓글 20개 더보기
댓글 달기
Turn Bluetooth on and off
해당 답변은 도움이 되었습니까?
점수 14
댓글 10개:
Worked like a charm thanks bud
Was having same issue.. Came here for answers...saw a thread that said turn Bluetooth on and back off....worked for me...
Thank you I'll try that
Wirked like a charm wow
댓글 5개 더보기
댓글 달기
귀하의 답변을 추가하세요
Jamie Duque 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 43
전체 시간: 199,787
