모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1171 질문 전체 보기
I received the same exact error code: 4SNS/1/C0000008:Ts0P--124
I'm working on a client's MacBook Pro 13" Late 2011 A1278.
I have the same issue. I removed the MacBookPro8-1.plist file from the original folder to bring the laptop to a usable state, but the fan still runs at 100%. I would say that it is still not running optimally (I have removed 13 malware items, but have not completely cleaned the system up).
I noticed some signs of corrosion (liquid spill) on IR sensor (on one of the ends of the Hard Drive Cable). I received the same exact error code: 4SNS/1/C0000008:Ts0P--124. Troubleshot every cable by disconnecting them, however, you can't remove the keyboard cable (as mentioned in the post above) because the power button is connected to it. Tried SMC PRAM resets, etc. To no avail. Also Temperature Gauge App (Trial) doesn't show any fan issues.
I will attempt to replace the Trackpad and let you know how it goes.
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
가장 유용한 답변
No, you can but you'll then need to use the power pads on the logic board to turn the system on or off. This is a test not a permanent solution. If the system is stable without the upper case keyboard & trackpad then you know you still have spill damage.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
귀하의 답변을 추가하십시오
Crypt0 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 262
