모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1171 질문 전체 보기
liquid spill, no power, faint ticking from capacitor(s)
i received a 2012 13" macbook pro (non retina) which had incurred some liquid damage. i've got a ton of donor books, so i replaced the dc-in board, as well as the battery meter board, but i can't get on...
when the magsafe is connected (for diagnostics, i've tried 45w, 60w, 85w) i get a very dim flashing light. the unit will not power on, nor indicate any charging.
i've attempted SMC reset, but the magsafe light doesn't indicate success, nor does the machine boot. i've tried shorting the power-on pins at the keyboard socket, which also doesn't work.
when the magsafe is connected, there are three blue/silver capacitors with the following text on each of their tops:
F37a
39
16V
and these capacitors emit a faint ticking sound. i'm fairly skilled in soldering and circuit repair, but not troubleshooting or part identification.
could anyone advise me?
EDIT: after pulling the logic board out, and placing my ear directly upon the board, they ticking may in fact be coming from the USB/firewire ports.
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
i have thoroughly cleaned the board with a toothbrush and 99% isopropyl. i'll i'll take some photos of the area i hear the ticking from tomorrow, and give the board number.
thanks!
의 답변
Put your finger over the caps feel if it's getting really hot , you got to step up your game board repair is 2 parts troubleshooting and physical rework , just saying :)) you got donor boards so you obviously are ready to kick it in high gear , youtube would be your best bet
의 답변
You need to start at troubleshooting your power rails it is not good that board is hissing or ticking noised
의 답변
I have absolutely no doubt I can perform the repair, But you're right my troubleshooting skills Peter out at the component level.
I am skilled with the multimeter but wouldn't know where to begin testing let alone what to expect. I took a peak at a circuit diagram, but it was a little... Abstract
의 답변
https://www.youtube.com/watch?v=D2u1zPgp... time to go to school bro everything on this channel will help you! Start with this video move on to the how to read schematics vid. May the force be with you Young Jedi.
의 답변
1에 댓글 더 나타내기
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
When there is ticking sound, mean there is shorted conductor(s) on the circuit board. The cap that you suggested as culprit can only be tested with ESR meter to know either they still good or not. Look around where the sound is coming from with the aid of magnifying glass to clearly see and test any available smd conductors.
Have a good luck.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Ronnoc Nailli 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 177
