주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Restore error 47. What could be the problem?
I'm getting restore error 47 when I try to restore my iPhone 5s. Some forums indicate that there could be possible hardware problem. Any help on what could be the problem with my phone?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 53
댓글 6개
What if its already in recovery mode and its doing the same error?
Yes Wayne, mine is already in recovery mode and i am stuck with this error.
Yes, it could be a hardware problem. I did some research and stumbled on this link... http://errortools.com/drivers/how-to-fix...
that link goes to a site infested with malware you @%^$$@$
Took my iPad 2 to Genius Bar & they tried to get latest iOS on it (9.3) and it got most of the way, before failing with error 47.
Less than 1 year old, it was replaced with a new one.
Its junk boys.
댓글 1개 더보기
댓글 달기
답변 8개
가장 유용한 답변
Put your phone in DFU mode, and try to restore. Also First check your HOST file to make sure there are no Apple entries. Last try a different computer.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
YES.justinm is right.
1) turn off the iphone and connect to the iTunes holding home key
2) restore via iTunes
your problem may solve
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hi,
The error 47 is a problem with the baseband or IMEI.
This can occur because of jailbreak and sim unlock.
If you don't jailbreak your phone, it can come from the baseband chipset.
Check that IMEI corresponds to that of the box of your phone.
For the baseband it must be 6.02.00 for an iPhone 5s iOS 9.3.4.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hello, how to check for IMEI if phone is in DFU mode, same for baseband, how do I check this. Many thanks!
댓글 달기
Error 1
Unable to downgrade. Try changing the USB port (the back one of chassis is better) and restart computer.
The installed version of iTunes may also be too old. Update iTunes.
Error -1
Error occurs when one uses the "last ditch" method for preventing baseband updates on the iPhone 4. The baseband does not get updated using this method. Use FixRecovery to kick it out of recovery mode.
Error -3
it you have Error -3 Check your Baseband Whene writing baseband in the phone the restoration stop check your Hardware baseband chipset
Error 2
Sn0wbreeze 1.6 Custom Firmware has a ASR patch problem. Use sn0wbreeze 1.7 or PwnageTool. Device isn't bootable.
Error 6
Not enter the downgrading mode, change USB port (the back one of chassis is better) and restart computer.
Error 9
Due to asr being patched, the SHA signature is automatically changed and after being resigned the kernel will refuse to use it. Therefore proper kernel patches are required. If necessary kernel patches are not applied, it will fail to load asr and error 9 would occur during restore.
Rebooting your PC may resolve this issue. Aslo it can be connection issue.
Error 10
LLB is missing from the IPSW. The device cannot be booted up. The trick to skip the baseband update no longer works.
Error 11
Removed bbfw file in the firmware folder of an unzipped IPSW.
Error 13
Occurs when you want to install a beta firmware with iTunes for Windows (actively blocked by Apple; beta users are developers and therefore must have a Mac).
Error 13 may also signify a USB problem. Check the USB connection and try other direct ports or maybe the USB cable is an older one. Device isn't bootable.
Error 14
Custom firmware update fail (PwnageTool). You have to restore the device with a custom firmware. Update to a custom firmware isn't working. Device isn't bootable. 2
USB Problem. Check the USB connection and try other direct ports or maybe the USB cable is an older one. Device isn't bootable.
Error 17
Custom firmware update fail (sn0wbreeze). You have to restore the device with a custom firmware. Update to a custom firmware isn't working.
Error 18
This occurs when the media library on the device is corrupt and cannot be modified or updated. Updating to the latest version of iTunes and then restoring should resolve this issue.
Error 20
Reportedly happens during failed downgrade attempts, Some have seen success afterwards by doing the downgrade from DFU mode instead of the normal Recovery mode.
Error 21
Error when using Sauriks server for a restore with iOS 5.x in the recovery mode at least on a A5 device. This error can also happen when you try to restore an iPod with hardware dfu. Use iREB r5 to solve this. or You are trying to update to a beta firmware without UDID activation.
Error 23
Baseband Communication error (Hardware), Most probably Baseband chip is faulty.
Error 26
False version of the NOR flash firmware. Use the correct sn0wbreeze version.
Error 27
modified the restore.plist so it would flash and also exchanged RestoreRamDisk and kernelcache. restore the original iOS.
Error 28
The problem is a bad dock connector on the iPhone. Must change the connector. If you have tried almost everything, reset the logic board leave uncharged for 2-3 days or remove battery for an hour. If doesn't work, the flash memory is damage .
Error 29
You might need to change the battery. See Apple discussions thread about this problem.
Error 31
DFU Loop, Sometimes during the restore with your messed-up IPSW, iTunes will return error 31. This is what's referred to as a DFU loop. The only solution is to restore a working firmware.
Error 34
Hard disk is run out of space when trying to download. Clear space and then continue downloading.
Error -35
Error when downloading songs purchased on iTunes, See Apple's KB article.
Error 37
iPod touch 2G LLB patched with the 0x24000 Segment Overflow was used on an iPhone 3GS custom firmware. Known on damaged bundles from unofficial PwnageTool distributions or bundles.
Error 40
Hacktivation bug in Sn0wbreeze, Use update one.. Headisk ...
Error 47
it you have Error 47 it a hardware problem with baseband Check your imei or Baseband
Error -50
Delete Storm Vedio, QuickTime, iTunes, then reinstall iTunes. See also Apple's KB article.
Error 1002
Are you restoring to a stock apple firmware or a custom pwn firmware? Either way make sure you are in DFU mode first.
Error 1004
This is caused by a failure to match the Baseband Nonce currently in memory to the Nonce returned in the BasebandFirmware SHSH blob. This is a normal part of iPhone 4 local restores via TinyUmbrella.
Error 1011
The file iTunesMobileDevice.dll is damaged or updated.
Error 1013
Restart computer; change computer; reinstall system, if iPhone is always in restoring mode: XP users can jump from restoring mode with ibus; MAC users can use iNdependence. (usually on the iPhone with 1.0.2 firmware downgraded from 1.1.1)
Error 1014
This error is down to itunes not liking your USB ports on your computer. Use a different USB slot or a different computer if possible. That is the easiest fix!
Error 1015
Restart computer; change computer; reinstall system, if iPhone is always in restoring mode: XP users can jump from restoring mode with ibus; MAC users can use iNdependence. (usually on the iPhone with 1.1.1 firmware downgraded from 1.1.2) Baseband firmware on the IPSW is higher than the baseband firmware on the iPad/iPhone.
Error 1050
Bad response from gs.apple.com OR need iREB for preparing the device for restoring to custom IPSW
Error 1394
When Spirit2Pwn flashes parts of the boot chain on iOS 4, the device may crash into DFU Mode.
Error 1413
Restart computer; change USB port; reinstall system. See also Apple's KB article.
Error 1415
Error 1417
Error 1418
Error 1428
Error 1600
Custom firmware can't be restored on a device with DFU Mode. Use Recovery Mode.
Error 1601
Completely remove iTunes and Apple Mobile Device support and then reinstall iTunes
Error 1602
Restart computer; change computer; reinstall system.
Error 1603
False kernelcache patch. Known on damaged bundles from unofficial PwnageTool distributions or bundles. See also Apple KB article
Error 1604
Device was not pwned (signature checks were not blocked). Custom firmware can't be restored.
Error 1611
iTunes tried to enter the Restore Mode, but the device turned back to the Recovery Mode.
Error 1618
Missing system files or corrupt data in iTunes installation. Try to uninstall iTunes, restart computer, install again. This error also occurs for iTunes in Windows 8 for reasons currently unknown.
Error 1619
iTunes is too old and couldn't read the iPhone in Recovery or DFU Mode. Please update iTunes and try it again.
Error 1644
IPSW was moved during prepare with iTunes. Try it again and don't move the IPSW.
Error 1646
iTunes expected the device to be in a different state (Example: booted into iOS rather than jumping to iBEC).
Error 2001
The Mac OS X kernel extension "IOUSBFamily" that was bundled with late 2008 / early 2009 MacBooks, has a bug where it fails to properly recognize an iDevice in DFU Mode. It can be resolved by updating to 10.5.7 (or later), or using a USB hub.
Error 2002
iTunes can't connect because another program is using it or it's disconnected during the Apple Server check.
Error 2003
Connection problem; change USB cable and check USB port.
Error 2005
Problem connecting. Probably a hardware failure.
Somebody reported that reinstalling the USB drivers fixed the problem.
Error 2006
Replace the USB cable with a newer one and/or disconnect all other USB devices, then retry.
Error 2009
remove all USB devices and spare cables other than your keyboard, mouse, and the device, restart the computer, and try to restore.
Error 3XXX
iTunes can't connect to gs.apple.com. Maybe Port 80 and Port 443 is blocked. Open it on your router.
Error 3002
Update to an older firmware isn't working, because Apple is no longer handing out SHSHs for the device/firmware combination.
Error 3004
No internet connection during the firmware restore.
Error 3014
False edited hosts. The SHSH request couldn't be completed. No connection to the Apple Server, Sauriks Server or localhost.
Error 3123
Something dealing with movie rentals.
Error 3194
Right-click on QuickTimePlayer.exe choose Properties from the shortcut menu click on the Compatibility tab. Deselect the checkbox labeled “Run this program in compatibility mode for..
Error 3194
Occurs when trying to install an old firmware and Apple's server disallows the installation. The only solution is to have SHSH backup and modify the hosts file to point to Saurik's Cydia server where they are backed up (or localhost if you have it yourself).
Error 3195
"An internal error occurred." Missing SHSH for the firmware. Maybe the same as "This device isn't eligible for the request build." but with an cache error.
Error -3198
Error downloading, try again. or This device isn't eligible for the requested build.
Error 3200
You are trying to update to iOS 5, when infact, the IPSW file has only a Restore Ramdisk.
Error -3259
Connection timeout, try again.
Error -5000
There is a problem with the permissions of the Mobile Application folder. The App you've tried to download in iTunes couldn't be saved.
Error 9008
Errors 9800
Set exact date, restart computer. See also Apple's KB article.
Error 9808
Computer system time incorrect.
Error 9812
Check system time, reset Internet connection, update root certificates.
Errors 9814
Errors 9815
Error 9843
This error happens if you are logged out, try to download something from the iTunes store and if you click on "Download" and enter an account, which doesn't have this article, this error will occur.
Error 11222
internet options Connections tab Click LAN Settings uncheck "use a proxy server"
Error 11556
You're trying to access a section or a functionality that is not available in your country, for example iCloud in some countries.
Error 13019
Seems to be an issue with syncing media to the device.It only seems to happen on jailbroken devices. Create new user, try syncing with new user's library.
Need restore the device....
Error 20000
Is caused by a custom theme pack on your Windows. Use default Theme.
Error 20008
This happened on a Mac with TinyUmbrella running before restoring a firmware to the Apple TV.
0xE8000001
Device was suddenly unplugged. iTunes couldn't connect with the device. Try it again
0xE8000022
Error in your firmware files. Restore.
0xE8008001
IPA signature verification failed.
0xE800003D
False permissions in the Carrier Bundle folder. Restore, update or fix the permissions from the carrier bundle to update the carrier settings via iTunes.
0xE800006B
Device was suddenly unplugged. iTunes couldn't connect with the device. Try it again.
0xE8000065
sn0wbreeze custom cirmware error on USB connection. Unplug the device, reboot it, and plug it in again.
The Old thread is here
Please Note : If there anything i missed, just leave your comment here.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
error 47 problem iphone 5
Any info on what Error 53 is?
댓글 달기
iphone 5 error 47 itunes
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Hi Jihad, I am also facing this issue, can you tell me how did get rid from this ?
Thanks
Pratik
I too have the same problem, no network connection and when I tried to fix it with itunes I got error 47 and it's stuck there. Please someone help!
댓글 달기
the iphone could not be restored an unknown error occurred 47
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
iphone 5s error 47 my phone is problem
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hello I have the solution, I had the same problem and went to the Apple Store, they tried to reboot it but it failed and they said I need to buy a new iPhone. Now my Iphone is back up and working just fine!!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
So How did you fix it Caden?
댓글 달기
귀하의 답변을 추가하세요
Ashok G 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 14
30일 전: 32
전체 시간: 68,743
