주요 콘텐츠로 건너뛰기
The 4Sight 9 is a low-end slate-form Android tablet released by 4Sight in March 2013. Identified by model number 4SPA0910C.
How do I perform a hard restart?
My tablet isn't working correctly and has trouble booting up, I was wondering how to wipe everything and restart it.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 1개
가장 유용한 답변
Trouble with Reset
If protection software does not correct the problem, on the back of the 4Sight there is a small hole that is labeled "Reset". Using a pen or a paperclip, insert the tool into the reset hole and you will fell a slight depress of the button inside. Pull the tool out of the reset hole and the device should be powering back on.
Trouble with Hard Reset
To proceed with a hard reset, there are several options for Android powered devices. Hold the "Up Volume" button on the side of the tablet, while holding the power button, this should start the reset process. If this does not work, you can try, holding the "Down Volume" button and the power button.
4Sight 9 Troubleshooting
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Robert Shredow 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 1,659
