주요 콘텐츠로 건너뛰기
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1262 질문 전체 보기
MacBook Pro boots after stop sign appears?
Hi there,
Here's the rundown: I have a mid-2012 13" unibody macbook pro. A couple of months ago I changed the original drive for a Crucial SSD, successfully, although I had to update the SSD firmware to fix lagging/freezing issues ; then a month ago, I updated to OSX Yosemite, with TRIM enabled, also successfully. About 2 weeks ago I upgraded the RAM from the original 4G (2X2G) to 8G (2x4G), again, successfully. Today I got a Patec HDD caddy in the mail, as I had planned to replace the optical drive with the original macbook pro hard drive. I followed a tutorial I found here, on this website and upon completion, when I tried to reboot, I was greeted by a grey stop sign on a gray screen, with an occasional flash of the macintosh apple... after about a minute and a half or two minutes, the login screen appeared and everything worked fine. I then shutdown the computer and rebooted once more, to see if there were any changes and the same thing happened.
Second to last thing I need to say is that I forgot to disable TRIM before messing with the hardware and it was advised to do so.
Finally let me apologize for any weirdness in syntaxe or wording ; english is not my first language.
THANK YOU IN ADVANCE!
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
2개의 답변
가장 유용한 답변
This is just a guess but both drives may have been selected as the startup drive. If you can boot from the SSD go into preferences and select it as the startup drive.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Did you format the original hard drive? Try doing a clean install and formatting both hard drives.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
StandingStone 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 522
