Trying to use and external microphone.
The internal Mic in my Macbook is broken. When I install an external Mic, it is recognized in the sound panel, but the system doesn't receive any input from the mic and I've tried several.
좋은 질문 입니까?
좋은 질문 입니까?
I would make sure that under System Pref, Sound, Input and Line In are selected which is obvious you checked that. How are you attaching the microphone? Is it a USB mike, through a mixer via the XLR ports, does the mike require a 9 volt battery if you don't have a USB or FireWire interface with phantom power? Are you attaching the mike through the audio port via a 1/8 inch jack cable?
Post your specs and maybe someone here can figure out a solution to get the MacBook to recognise the mike.
steve
해당 답변은 도움이 되었습니까?
It's just a standard non power mic attached to the 1/8 audio in jack. I have three USB ports and with firwire and the headphone in/mic in ports.
People have suggested using a USB mic instead.
Thanks.
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,261
