주요 콘텐츠로 건너뛰기
Samsung Galaxy Note II는 대형 스크린과 필수 자체-저장 스타일러스로 최적화된 소프트웨어가 결합한 스마트폰입니다.
211 질문 전체 보기
Cannot connect to wifi
my phone's wifi is not working
my wifi signal strength is very strong but it's not able to connect
the status shows obtaining IP address
and after a while it tells network disabled. Poor connection
I checked on the net they say it's because of the update of the phone original version 4.1.1 to 4.1.2 jelly bean, the update is causing the phone wifi connection go crazy
I checked for the solution, in many forums they showed to change the IP settings from DHCP to Static which I did and then after entering the wifi password there is no save option
I tried this way too..the link is below
https://www.youtube.com/watch?v=zyO66lqT...
the first way is dialing *#0011# but it's still not connecting
the second way was too confusing so I didn't try
I checked it online and I guess this problem does not only happen in note 2 but almost all the android phones
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 5
댓글 1개
I have the same problem suddenly in a day. I reset my phone once and I downloaded the wifi fixer, diff., versions, it just does not work.
댓글 달기
답변 6개
가장 유용한 답변
my phone is not connecting to wifi and bluetooth
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi Smriti
Have you thought about the wifi antenna being faulty and to try a replacement?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
2nd Rssi is not available
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
disconnect then put your password back in. that what i did.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I can not connect wifi in my mobile
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I would recommend replacing the WiFi antenna.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Smriti Sharma 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 25,349
