주요 콘텐츠로 건너뛰기
Launched in October 2014, identified by model number CHDHA-301.
24 질문 전체 보기
Why won't the charger fit into my GoPro Hero?
My GoPro Hero is dead and needs to be charged. Unfortunately, every time I attempt to connect the charger to the back of the board, it doesn't quite fit into the slot. Can anyone help?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
Take a second to look at the back of your Go-Pro. Look at the slot that the charger typically goes into. Does it appear to be aligned with the casing? If not, this could be the first problem. In order to fix this you must pop off the back of your go-pro. Take into account that your Go-Pro does not actually come out of the clear skeleton case. Instead, the grey or black chasing should come off with a little leverage.
If you're having issues doing this, look up the device page on Ifixit and the guide for this will be there.
If everything looks aligned, and there are no crumbs or small bits clogging it, then look at the charger itself. Ensure that the end of the cable doesn't have anything stuck in it (i.e. food, dust). If it does, take tweezers and attempt to remove the small pieces.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
There is no small bits of food are stuck inside my chargers ng port at all,
it's just my my charging won't fit instead de the. Hanging port,
And sometimes I had to hold press the charger in to the charger port till it's start to charges . And I try doing it again to hold press . But it's does not work anymore,
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
my GoPro didn’t come with a charger so I bought one for My GoPro and it won’t fit in the hole any suggestions what I should do oh and it’s low on battery
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Zoe Tuggle 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 11
전체 시간: 4,007
