주요 콘텐츠로 건너뛰기
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
3DS won't stay stay on - makes a popping sound
Hello,
Recently I changed my 3ds LCD screen.
But once I tried to turn it on, it made a popping sounds and turn itself off after a few secounds.
I read about lossen ribbons and stuff, so I tried to disconnect everything and turn the 3DS on just to see if the motherboard can light up.
The blue light turns on for a few secounds before shuts off.
Could it be a blown fuse? I saw once that with blowen fuse the nintendo won't turn on at all..
What could be the problem? I discconected EVERYTHING, even the mic, and still it won't stay on!
Thanks.
- Theres no SD card inside.
- Theres no game inside.
- tried putting the motherbord inside a fully functationing 3DS XL.
- It charges.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
When it shuts off does one of the screens flicker for a split second? If the bottom screen flickers then there may be an issue with the top lcd. The 3d flex cable is usually the culprit. The ribbon may have a slight tear that is preventing the top lcd to power up which results in the blue light shutting off. To replace it requires a complete tear down of your system.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
No flicker when I turn it on.
댓글 달기
It absolutely will not power on if any of the ribbons are ripped or disconnected. Try reconnecting everything and look if the cables are ripped.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
ChubbyKai 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 10
전체 시간: 1,275
