주요 콘텐츠로 건너뛰기
Apple의 MacBook Pro 노트북 라인은 전문가 및 파워유저를 위한 제품입니다. MacBook Pro 라인은 MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17" 및 MacBook Pro 17"Unibody를 포함합니다.
19981 질문 전체 보기
what is best battery maintenance?
what is the best battery maintenance practice for the battery life of my MBPro 15"?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 6개
선택된 답변
Definitely check out the blog, as Ben suggests!
A quick and dirty answer for you, however:
If you use the machine as a portable computer on a regular basis, you probably don't need to do much else.
If you use the machine as a desktop replacement which never leaves the charger, then you will want to force it to run on battery (until it gives first low battery warning) at least once every 3 months, to exercise the battery.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Hello!
We actually just recently wrote full coverage on this very topic on our iFixit blog! Check it out. I believe you will find all the information you need there (better than I could explain here, at least)!
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I know this doesn't help, or really answer the question, but my attitude towards batteries and computers in general is that they exist for our purposes and for our convenience, so to take up our own time in order to make a battery happy and meet its needs is fairly self-defeating. Besides, it's very difficult if not impossible to ever know whether or not how you've cared for or not cared for a battery led to it living an extra 90 days, or dying 90 days earlier. I say, just forget about the battery! :-) Anyway, just my two cents.
In the 80s/90s when we had inferior NIMH and other battery types which had a "memory" and absolutely needed to be fully charged/discharged, behavior toward a battery was much more relevant. But now that we have lithium ions which are far less temperamental, again, it's near impossible to tell if your behavior is affecting battery life, yet opinions on how to treat batteries still persist.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Pretty much the thing to do is calibrating it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I own a MacBook Pro and the battery life just wasn't good enough for me. I got only a few hours per charge and that is if I was lucky. My eventual solution was to get an external laptop battery from Novuscell Batteries. So far, no regrets because I'm now getting an extra 12+ hours of battery runtime per charge on my MBP.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Looks like the blog link is dead. Too bad, it was probably nice.
Lithium batteries have four enemies:
  1. Cycles. You have to use them, of course, it’s why you bought a laptop.
  2. Time. Nothing to do about this.
  3. Heat. Stay away from it. Leaving it in your car in July is a bad idea.
  4. High voltage. I use my pro as a desktop, with the charger always connected. This keeps it fully charged. The high voltage condition causes significant degradation over time. Fortunately, some manufacturers allow you to configure charge termination to some lower percentage to extend battery lifetime. You can charge to full if you’re getting on a plane. Apple does something similar. It is adaptive. It learns your habits, and backs off on charging accordingly. I don’t know what their algorithm is. There’s not much you can do except not to charge to full when you know your machine will be off for a few days.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Rick 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 9,184
