screen crack but phone works fine
Do i need to replace the lcd screen only or lcd screen n digitizer
좋은 질문 입니까?
좋은 질문 입니까?
You should replace the digitizer and glass as they tend to come as one unit and it is harder to remove the digitizer from the glass. Here is a how too video.
https://www.youtube.com/watch?v=vz2lblnG...
an Idea of price from amazon
http://www.ebay.ca/sch/i.html?_odkw=Sams...
Hope this helps
해당 답변은 도움이 되었습니까?
you do not need to replace the LCD if it still works the LCD can be pricey for this unit
you only need to replace the screen and not the digitizer. be careful though it is extremely easy to damage the digitizer while replacing the screen if you are not careful. make sure if you do it yourself do not use too much heat and when getting the glass off use something like a playing card to get under it so that you do not damage anything. good luck with your phone
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 104
