주요 콘텐츠로 건너뛰기
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 질문 전체 보기
iPad 2 screen not working after repair
I replaced the battery in an iPad 2, and because I broke the power button cable in the process, that too. The screen worked fine after the button cable replacement, but I didn't plug the cable into the board right so they didn't work. I took the iPad back apart and re-seated the cable. Now the screen doesn't work. My computer recognizes it just fine. I checked both ends of the screen's cable to make sure they weren't damaged and that they were seated properly. Is it possible that the problem is with the lid sensor? How might I check or troubleshoot?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Hey,
It's an old question but still: first thing you need to do after such a repair is to reboot your iPad.
To do that, press and hold Power Button + Home Button together for ~15 seconds until the iPad has restarted and you can see the Apple. If that doesn't help, you'll need to report back and get help to further trouble shoot your device.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
You may have a faulty LCD, if the iPad was not turned OFF (not sleep, but off) then it can damage the LCD backlight.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
accounts 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 122
