How do I change my fuel filter
What steps and how do I change the fuel filter in my 2010 Honda Civic?
좋은 질문 입니까?
좋은 질문 입니까?
Albert Miller, it is bundled with the fuel pump, pressure regulator, and fuel level sending unit in the gas tank. There is an access panel in the trunk in the middle of the floor right behind the rear seats
해당 답변은 도움이 되었습니까?
Your car does not have an (external) fuel filter like older Civics. It does have an in-tank filter that is connected to the fuel pump, which is in the fuel tank.
해당 답변은 도움이 되었습니까?
How would i drain all the fuel out ?
On most modern vehicles, the fuel filter, fuel pump, sensors, and other ancillary hardware are all located in the gas tank. They're designed to last the life of the vehicle and as such aren't easy to service. Gasoline is pretty clean these days so there's little reason to change the filter unless you have a specific reason.
해당 답변은 도움이 되었습니까?
Pick problems in hilly areas. Sometimes raise in temperature by two bars
해당 답변은 도움이 되었습니까?
My 2006 Honda Civic hybrid keeps jumping as I'm driving what would cause this
24 시간 전: 20
7일 전: 99
30일 전: 442
전체 시간: 47,142
댓글 1개
Location of fuel filter on Honda covic
John Kulp 의
