Why my steam iron can't get steam come out
The steam iron, I get the problem is steam don't came out...when I press the pressure button on the handle ,steam don't came out n the water still get boilling no steam out. How can I fix it?
좋은 질문 입니까?
좋은 질문 입니까?
Hello,
I would try using a 50/50 mixture of distilled water and vinegar. I use this mixture to clean my coffee pot and steam mop. 90% of the time it works everytime!
해당 답변은 도움이 되었습니까?
Hello!
I just find some good web page. This problem is related to electronic, pump power supply.
https://lieven.kks36.be/2016/06/11/phili...
I hope it will help You.
Best regards!
Marin
해당 답변은 도움이 되었습니까?
How can I solve my steam generator problems, it do trip off if you pressed pressure bottom on the handle and steam doesn't come even after I cleaned it with 50/50 with white vinegar. Bello
Brilliant thank you. It's working now. 😁👏
Try opening cap where the water is topped up. If it starts to steam then, on my Philips Azur, there are two tiny pinholes in the cap which were blocked. A poke with a pin was enough to sort the problem. They allow air to enter as it steams, otherwise a vacum would occur and stop the water flowing.
해당 답변은 도움이 되었습니까?
24 시간 전: 7
7일 전: 107
30일 전: 439
전체 시간: 67,892
