IPAD red fuzzy screen replace LCD?
I attempted to replace the digitizer on an ipad 2 and since then the screen is doing the red fuzzy thing. I have tried unplugging and plugging the LCD connectors and doing the drop/slap solution but it is still red and fuzzy. Is this an issue with the LCD itself or with another component? I can replace the LCD if need be.
좋은 질문 입니까?
Thatnks for the reponse. I have tried all the above. The logic board and connectors look absolutely fine. I have ordered a new lcd cable just in case but i dont think this is the issue. Would replacing the lcd solve this problem or is it another part that is at fault?
Simon Milo Mitchell Jones 의
75% can be solve replacing LCD, 25% it can be motherboard fault. Change the new display and let me know the status, if same fault observed i will help you to fix the fault on logic board.
Buddhika Mahesh 의
Ok thanks. I will keep you informed.
