주요 콘텐츠로 건너뛰기
A network storage device available for home or business use.
1 질문 전체 보기
Power status light blinks, indicating failure. HD clicks. Is that all?
I inherited a Maxtor Shared Storage II NAS. After sitting unused for some months, it now won't work; the drive makes a clicking noise periodically (I know that's not good), plus the power status light on the front blinks freen, continuously and rapidly, which from some googling indicates failure. I tried the reset, no joy. Not visible on network.
Question is: should I just junk it, or will replacing the drives possibly fix it? I don't even know where the OS is stored--in firmware, or on the drives?--and don't want to spend a lot of time on it myself. If there's a chance it's just the drive, I'll yank the drives out (it's my client's data) and sell the enclosure to someone who cares to fiddle with it.
I did find lots and lots of posts online about these failing, but a lot of them had to do with the Seagate drives inside, which may have fallen victim to the firmware bug last year.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
I would first remove the internal drive mechanisms (isn't this a dual drive unit?) and test them
the clicking sound doesn't sound promising, that's likely a drive about to go. but I've also seen several external drive enclosures with dead interface logic, meanwhile the internal drive was fine. anyhow if this is a dual drive unit, then perhaps you can at least salvage one drive and reuse in another external enclosure.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks, I'm not worried about the drives (new drives are cheap enough), just wonder if it's worth trying to salvage the enclosure.
댓글 달기
귀하의 답변을 추가하세요
colleenthompson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 2,892
