주요 콘텐츠로 건너뛰기
The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
201 질문 전체 보기
Phone won't charge, charge slot burned
The other day charging my phone, my phone charger ended up burning my charging chip inside my HTC M8. The phone still works but when attempting to turn it on, the phone just keeps showing it is at 0% even with multiple different tries using different chargers. Looking inside the charging slot you can clearly see the chip is toasted. Is this replaceable and or fixable? I rather fix it, even if it's by someone else than to buy an entire new phone.
Thanks ahead
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 13
댓글 4개
GTABobby, What do you mean charging chip? There are tow PM IC to powering up your HTC M8, but non of they are located around or inside charging port.
The charging port is burned, I can not charge it. The USB is clearly burned from the inside because my phone charger overheated the phone and it ended up getting burned. The phone still says 0% and appears to work fine if it becomes charged but getting it to charge is the problem.
if you can clearly see the burns, then that must be the culprit, i might even advise you to repalace the battery if you plan on taking the phone apart..
the same thing happend to me but with my galaxy s4... if someone knows if this is fixable please let me know
댓글 달기
답변 5개
선택된 답변
To burn charging port required high power current. if you use 3rd party bad quality charger it cause to pass 220V/110V direct to your phone and cause to burn charging port.
Here HTC One (M8) Teardown guide
Check in below charging term having any component burned damaged or missing
https://d3nevzfk7ii3be.cloudfront.net/ig...
Check both PM ICs (PM8941 PM8841) and the any short circuit in Micro USB pin1 and pin5
you can change the charging port with flex in any damages not found on motherboard.
by the way you are very lucky man as your battery didn't explode near your face at that time!
Good luck!
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
im haing the same problem , am I better to just buy a new phone?
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
You might have to get a new phone. But before you do that its best to disassemble the phone to see if the battery or circuit board is burned. If any of those two or both are burned. That might be why the phone charger is burning. But you could also call your provider or the place where you got the phone.
i think you should just get it fixed
@mune_mage i got the phone from a friend and my question is how much it will cost to get both of those fixed
Mine is a TCL A3X nu charger head got burned n affected my phone. The phone works perfectly OK but it can't charge. I don't where the fault is coming from
댓글 달기
If you want to replace M8 USB port, that's the guide https://www.youtube.com/watch?v=QQjJkkok...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
my iPhone 5 chip in the inside is burnt and WONT CUT ON I tried getting a new charger but that did not work the phone wont cut on and when I look in the inside the charger chip is burnt I wanna know how much it will cost to fix it and what is wrong with it I think both the battery and the charger chip is the problem type bye Travion.mcgaughey
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
any answers to my question
댓글 달기
When I plugged my Samsung s8 plus in I saw smoke coming out of the charging port then the next day it didn’t turn on at all.Anyone know why?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
GTABobby 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 80
전체 시간: 41,418
