주요 콘텐츠로 건너뛰기
2011년 10월 24일 출시 / 2.2, 2.4, 또는 2.5 GHz 쿼드-코어 Intel Core i7 프로세서
401 질문 전체 보기
How to fix dead keys?
Several keys are dead: <left cmd>, plus <c> through <m>, <,>, and <.>. Is there a repair guide for the keyboard itself? How about replacement parts?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개
OK, I found a bunch of YouTube videos showing the teardown plus a few showing a cleaning procedure for the keyboard (in particular, Louis Rossmann's replacement video. I am still interested in sources for the parts, chiefly the keyboard.
댓글 달기
답변 2개
선택된 답변
Sounds like you have had a short. The keyboard will need to be replaced. The part can be found on eBay usual about $25-$40. Make sure you get the one for your machine and with a back light (a little more). The cable that connects to the logic board is slightly different on some machines. It will take you a while to remove the approximately 85 tiny screws and put them back in. I use an electric screwdriver to remove them. The job takes me about 1 1/2 hrs to 2 hrs. to complete but I've done it a lot. Add an extra hour and try not to be disturbed. Here a guide for the 2010 machine but is the same for your 2011: MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
Hi,
my sdfghjkl keys do not work on a MacBook Pro 13 inch April 2011 (i5)
how can I test them?
how do I know which type of keyboard to look for on Ebay? I find it stupid to pay 200 USD or more to change the whole front!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I also have the same problem. Is yours already fixed? What did you do? Thanks
댓글 달기
귀하의 답변을 추가하세요
Arthur Ogawa 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 7,407
