주요 콘텐츠로 건너뛰기
The sixth-generation Honda Civic was introduced in 1995. It retained its class-leading handling as it, along with the fourth and fifth generations, had front double wishbone suspension, the advanced independent suspension inspired by Honda's racing research.
52 질문 전체 보기
Engine code for Honda civic
What dose engine code d0135 mean for 1999 Honda Civic
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
가장 유용한 답변
Joeb, never seen a D0135, only a P0135 which means "Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)" To repair that I would start by replacing the oxygen sensor as well as checking the wiring harness to make sure it is not damaged.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I had quite an issue with my 1998 Honda Civic HX, told me the oxygen sensor was lazy, even for a new sensor. Turned out that the ECM needed more recent firmware, but an update was not possible. Ended up getting a replacement ECM which cured the problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Joeb 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 798
