hami, try these things first. Be sure that Compatibility Mode is not enabled or not checked (right-click on Skype shortcut icon/launcher and select Properties >> Compatibility). Then try it. If still nothing, try to Clean Skype Folders/Files
A. Close Skype. Type or enter %appdata%\skype in the Run command, then click Ok. Look for and delete the file named Shared.XML (a fresh copy of the shared.xml file will be recreated when you login, the previous one may be corrupted causing Skype not to run properly). Restart your computer.
B. With Skype not running, Type or enter %appdata%\skype in the Run command, then click Ok. Delete temporary files all the files starting with “temp-“ or ending with “-journal”, and files with extension “.lock” and with size 0 KB . Then reboot your computer.
If you do not already have done this, set IE as your default browser.You can also try to delete temp internet files and clear cache. If possible, also disable or remove any unused or possible corrupted Internet Explorer plugins/add-ons (regardless of the web browser you set as default, Skype uses IE engines).
You can also try this if the aforementioned does not work:
1.Click Start, click Run, and then type regedit in the Open box, and then click OK.
2.Locate and then click the following key in the registry:
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Internet Explorer\Restrictions
3.If a value named NoBrowserOptions exists, delete it.
4.Locate and then click the following key in the registry:
HKEY_CURRENT_USER\SOFTWARE\Policies\Microsoft\Internet Explorer\Restrictions
5.If a value named NoBrowserOptions exists, delete it.
6.If you are using 64 bit version of Windows, locate and then click the following key in the registry:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Policies\Microsoft\Internet Explorer\Restrictions
7.If a value named NoBrowserOptions exists, delete it.
8.Restart the computer.
댓글 8개
What operating system does your computer have? Win 7/8 ?
oldturkey03 의
it has windows 7 64 bit
hami 의
Any internet connection issues? How do you connect?
oldturkey03 의
I dont think i have internett connection issues, because my google chrome and internet explorer works fine with the internet. Im connected with WIFI
hami 의
What other programs do not work for you?
oldturkey03 의
댓글 3개 더보기
