it does not work with out being charge
I need a charger for my kindle fire .it does not work with out being charge so please help me to get it fixed.so what do I do ? :-)
좋은 질문 입니까?
좋은 질문 입니까?
jerry Evans, here is my answer to a very similar question :"disassemble your Kindle. Follow this guide. You should check the solder connection on the micro USB port. It is very likely that they have either come totally of the board, or that they have micro cracks. It might be possible to reuse the old connector and resolder it, or you may have to find a new connector. If you need a new one, you could check mouser.com or digikey.com for a micro USB that fits the dimensions of your Kindle." For more information, check the answer from John Painter on this question not charging This job will definitely require some soldering. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 43
댓글 1개
The part were you plug the cord in is broken and it needs fixing very badly so how do I go by getting it fixed .
jerry Evans 의
