주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mag Instrument(Maglite)의 미니 마그라이트 2 AA 제논 손전등
batterey replacement fir my Mini Maglite AA
I did what you said but when I removed the disc there is another
black plastic device that looks like it has to come out the other end because there is a lip holding it in place
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
I tried to take the end cap off with two wrenches and it wouldn't budge.
It's now soaking in WD 40 and hopefully that will work.
If not it'll get the deep six!
댓글 달기
답변 3개
선택된 해법
Unscrew the cap on the end opposite of the light bulb.
used Ikea AA, after a year, how can get the battery out?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
The answer above, "Unscrew the cap on the end opposite of the light bulb." doesn't answer the original question regarding removing the second piece of plastic under the lightbulb holder. So, no, the question was not answered.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
You can gently pry that black cap off using a small flathead screwdriver. Under that you’ll see a black piece that holds the bulb in place and the electrical connections. Push that backwards out the end of the tube away from the head.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
rondon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 1,999
