A frame around the touchscreen loose again
hi i need help my ipodtouch's frame around the touchscreen is loose it moves up and down how can i tighten it so it doesent move please help
좋은 질문 입니까?
좋은 질문 입니까?
Hi.... This is not an easy task and unless the looseness is impeding the use of the iPod i DONT recommend attempting it as you may cause more harm then good...
If you want to go ahead with the repair follow this repair guide:
iPod Touch 3rd Generation Teardown
up to step 4. after you have completed step 4, CAREFULLY bend the metal tabs around the frame towards the outside if the ipod, then reassemble the ipod in reverse order.
If your ipod us still under warranty I would call apple as they will be more than happy to send you a free replacement ipod.
Hope i was of some help.....
Darren
Apple Certified Macintosh Technician
London, Ontario, Canada
해당 답변은 도움이 되었습니까?
i got my ipod on may 4th why do u think it the frame is moving
oh yeah and when u were posting this anser i was reading the teardown
It can be moving for a number of reasons..... you are still covered under Apple Care so I would give them a call .... where are you located an ill provide you with the correct phone number
Darren
i can do the teardown till #4 but i cant open the ipod up because i dont have the tool to do it. are there any other tools thai can use to open it
Darren
해당 답변은 도움이 되었습니까?
The best tool I have found to open the iPod touch without cracking the digitizer is:
Darren
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,483
댓글 1개
i placed the device in the correct category - the 3rd generation ipor touch with 8gb is "only" a 2nd generation device
markus weiher 의
