주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1500 질문 전체 보기
질문 마감됨
Why is my phone not charging or being recognized by PC?
Hey can anyone help me, my iPhone 3gs isn't charging, but when I plug it in to computer it turns on but then doesn't charge or appear on itunes or the computer.
I have just replaced the battery because the old one swelled up.
Any help would be great, thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Update:
I have ruled out the cable because both my ipod and iphone 4 charge with the cable.
I just finished replacing the dock connector but now the screen is white when I turn it on :(
Any advise?
댓글 달기
답변 2개
가장 유용한 답변
Hey Dmtech94, it could be that the new battery is faulty or the charger is broken. Check to see if the charger is broken, then if it still doesn't work then replacing the battery again would be another solution. Another solution, if it doesn't work after is to replace the logic board.
-Let me know how it goes.
iPhone 3GS Logic Board 이미지
안내서
iPhone 3GS Logic Board Replacement
난이도:
운영
iPhone 3GS Battery 이미지
안내서
iPhone 3GS Battery Replacement
난이도:
운영
20 - 30 minutes
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
Update: I have ruled out the cable because both my ipod and iphone 4 charge with the cable. I just finished replacing the dock connector but now the screen is white when I turn it on :( Any advise?
Dmtech94, check to see if the screws were placed correctly and make sure everything was properly reassembled. If it still doesn't work, press and hold the power and home button for 10 seconds until the screen shuts of then right when it turns on let go.
I tried what you said but it just stays white :(
I made sure everything is properly reassembled and it still is white, could it be the logic board?
Yes, as I stated in the answer if nothing else works then changing the logic board would be another solution.
댓글 달기
Dmtech94, since "doesn't charge or appear on itunes or the computer" I would suspect the dock connector. First of course try a different cable and a different computer. Check the dock connector. Make sure that you clean it with some isopropyl alcohol and a few puffs of compressed air. If the results are still the same, replace the dock connector
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
give this a try. Press and hold the home button, the up-volume button, and then the sleep/power button at the same time. Press and hold until the Apple logo appears, release all the button s and see what happens.
Yes it can be, but before anything else, check this video and se eif that will work for you. Also, check your LCD connector and see if the contacts are not bend etc.
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 146
