주요 콘텐츠로 건너뛰기
The Epson WF-2540 is an all-in-one color inkjet printer. It features a 2.5-inch LCD touchscreen and four individual ink cartridges.
82 질문 전체 보기
Image won't print at all
I can't get an image to print despite completing nozzle check, head cleaning and head alignment,
Ink levels show ok, paper comes through with no image
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 81
댓글 50개
I have exactly the same problem and the Epsom support team are useless. I've bought new cartridges and done all the cleaning and aligning in the world. Nothing works.
The Epson support team told me to do the same as you; it did not work; I looked for someone to clean the nozzles with no success. I was told that if I found someone it would cost more than purchasing an entirely new machine. So my Epson is in the garbage.
I have the exact same problem it used to print now it won't. It's driving me mad. I've done everything , it just won't print.
Unfortunately, when I purchased my all-in-one-printer, HP did not have any that were similar. HP has always given me good service. I realize this remark is useless in regard in Epson.
Have the exact same problem, even bought new ink thinking that was the problem. Have had the machine for about 5 months, hardley ever use it. I'm furious and frustrated with this stupid machine. I will never purchase epson again
댓글 45개 더보기
댓글 달기
답변 23개
선택된 답변
I was having this problem as well. Nothing but blank pages coming out of my printer. After first making sure my drivers were up to date off off Epson's website. I contacted Epson and they asked if I had done a head cleaning and nozzle check (these can be done through your Maintenance Topic on Menu) and I said yes I had with no help. They had me run it again and the colors came through. Then I ran a third time and the color were even better. Then a fourth time and even better. Here is my verdict: If you are having blank page problems run a head cleaning more than once. It helped me after multiple runs. Hope this helps.
해당 답변은 도움이 되었습니까?
점수 25
댓글 27개:
Thanks this did the trick!!
Yes, it worked, performed nozzle check and head cleaning for the n th time.
trying now hope this works lol
Did it a dozen times, still no results.
Would not have believed it if I didn't see it, But worked after the 8th time of running the head cleaning and nozzle check! Thanks for this thread, I was Almost ready to smash this WF-2650 to peaces after owning the printer for about 1 year with very little use! Noticed after doing the head cleaning the levels of all ink cartridges dropped to 1/2 after just putting in New XL genuine Epson brand.... I printed 2 pages in Black and White and just a few lines of each color, So where did all the ink go?
The printer we owned before this one was a cheap HP that lasted 4 years and broke only because it was knocked off the table. I will be buying HP brand next time.
댓글 22개 더보기
댓글 달기
Hello Nelson , excuse my english because i'm an algerian, i would like to help you, if i understand your problem ,even if your ink is ok and your paper too , the paper still white without impression, i have an idea for you, you know when you make a cleaning of noozles or when you charge new cartridges in the machine there is a pump which the role is to pump ink through noozles so i advice you to check this side of your printer, and mostly a pipe who is fixed under the carriage in one side and in other side to the vacuum pump, sometimes this tube is disconnected from the (charriot en francais) carriage of parking , so when you believe that you are making a charging ink or a cleaning , the ink doesn't move through noozles and the head it's empty of ink therefore you have not impression even if the head moves like she does normally,and also this pipe can be clogged with dry ink, so you have to assure that he is not clogged, to do this easily, look at the back of the printer you 'll find a little door, open it and you'll see a grey little pipe ,so remove it and put it toward the outside and put under it a bottle or something like this to keep the ink while you clean or you put on your printer,if ink came out from this tube you have a proof that your tube is well fixed and your pump ok,but if no ink came out you have your answer remove and fix the pipe correctly, so i'll be happy to help you, and i hope that you 'll able to fix your problem! if you want to ask me other questions this is my mail
해당 답변은 도움이 되었습니까?
점수 5
댓글 7개:
Sorry this is my mail , i'll enjoy to have news about your repair Good luck ! hadsof2002@yahoo.fr
My WF2540 does not have a trap door in the back or anywhere I can see.
Loved the idea of checking the pump...if I could find how to get to it!
I actually made the solution to soak the print heads about 4 times one day and about 3 times today, to see if it would melt the clog. No black ink when printing.
No one should have to perform such tasks to be able to use a WiFi printer. Epson 2540 uses crazy amounts of ink if it works but most often it doesn't print so no worries on replacing more ink!!!! Piece of garbage printer Epson WiFi 2540 !!!!
댓글 2개 더보기
댓글 달기
Have been able to air print and print directly from computer maybe 4 times since buying this useless printer over 4 years ago. I actually got it to copy yesterday for first times in months but now print is extremely large and I never made that adjustment. Plus the ink needs to be replaced way too often. Put all new cartridges in two months age thinking that might help. No! Nothing. And now three cartridges are low? I am not a computer geek but nothing adds up. I think the best idea is just toss the Epson 2450 WiFi air jet printer in the recycling bin. More than frustrated. VWB
PS. Even if one was super savvy on computer issues, why should you have to spend more time fixing a printer than you do typing your best selling manuscript? Absolute waste of hard earned money!!!!!!! Do not consider buying this piece of garbage printer. My toner printer was much more reliable. It never failed me.
해당 답변은 도움이 되었습니까?
점수 4
댓글 3개:
What a useless printer 2540. All complaints I read are the same!
Time to toss it and by a consumer recommended one.
My printer s two won't print at all. Very frustrating.
i AM super savvy on computer issues. I'm 3rd level tech support for a large company. I will NEVER buy Epson or Brother again. Epson makes great commercial POS printers but that has not translated into high-quality products for SOHO.
댓글 달기
I hit clean heads six times and suddenly I got a faint print job. Hit it again and all is well!
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I found the answer - someone said on another site that this printer can not run 64 - you have to install 32 so I just installed the 32 bit program and am going through the prompts - printed the test page and it works. I have a printer that prints now. It doesn't print that great actually but it's printing. I think from all the cleaning the other inks are low now but they should work.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
The Epson WF-2540 uses the same driver for both 32 & 64
Yeah, this answer doesn't make any sense. The driver package supports both 32 and 64.
댓글 달기
I ran the head cleaning 3 times and the color came back when I ran nozzle check, but no black. I ran it 4 more times; still no black. I then did the manual disassembly and cleaning shown here: https://www.youtube.com/watch?v=Xb7Bc1jG... and put a fan on the head for 15 minutes to make sure it got dried out and still no black. I ran the head cleaning 3 more times. No black. And over the course of all these cleanings the color actually got worse. A week later I ran the nozzle check again: no black. Then I head cleaning utility again. All my colors are back, including black! So for what it is worth: persevere! Save another printer from a landfill! Thanks to all who posted their extraordinary efforts which encouraged me to persevere :-)
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
In the end, I gave up. I only print about once a week. Half the time in that intervening week it clogged and I had to run the head cleaning utility which always worked but I got tired of it because it uses a lot of ink to clean the head. I punted after all that work and replaced it. I tried to save it from a landfill, I really tried! :-(
댓글 달기
Hello everybody the only thing which is going to work is to keep cleaning the head sometimes you will have to do it 25 times i have fixed multiple epson printers by keep doing that just dont print nozzle pattern keep cleaning over and over till you get the result
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
try this
http://www.inkmagic.com/shopcontent.asp?...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I had the SAME issue with my WF-2650 which I purchased less that 1-yr ago.
Even though I had just recently purchased a large quantity of ink for it, I was ready to throw it away.
I patiently ran the nozzle clean time and time again.
After about 15 nozzle cleanings... I prints perfectly.
BTW: I know where you can purchase "CHEEP" ink cartridges for this printer.
They are about 80% less cost than ones purchased at office supply stores.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Where did you get them if I can get it to print again
amazon.com sells them.
댓글 달기
First I cleaned the printer nozzle. That didn't work. Then I cleaned the printer head. My printer started printing again. I would try that.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
did you manually clean the printer head? or did you run it through the printer command? I've done this multiple times and still doesn't work.
댓글 달기
Ran the printer's function to clean printhead nozzle three times. Back up and running! Thanks all for posting
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I am having the same issue and at first, I liked the conveniency of printing out paper through your phone, laptop, and other devices. At first it was quick and it got the job done. Now, I noticed that it doesn't print, I had ink already and when I was trying to clean the nozzle, for some reason it took all my ink and I had to buy a new one. I noticed it did it again and it work a little, now I am buying new ones to see if this time it will work. Epson Representive did explain to me that if the printer isn't used for a while, the ink dries up, making it hard to print. I will not purchase any Epson or recommend Epson to anyone anymore. Same for my Mother's printer did the same thing.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
we spend 3 hours trying to fix the same problem but this piece of "shout" machine is not good at all and people that bought an EPSON printer should be reimburse their money .
댓글 달기
Service manual? I am an autotech maybe i can make something happen.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have one of these at home and it works great, this one at the office, at first it started printing FUZZY, then I cleaned the print head and it started showing drag marks from the cable, then I set the printing effect on high instead of standard. It took longer to print but it was a bit better but not clean. I took the cartridges out and cleaned them and then replaced the print head. NOTHING but Blank paper. I'm over this stupid printer.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I removed the ink cartridges, cleaned the prongs that they sit on using cotton swabs and rubbing alcohol. Dried with cotton swabs, replaced cartridges and it prints.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
After head cleaning and head alignment checks: Remove the black ink cartridge. Spray it and the inside pocket where it sits in the printer with compressed air. Replace cartridge. One more nozzle check. This has worked for me on two Epson printers as I travel back and forth. Always have a can of compressed air. Miracle stuff!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I did what most people suggested and ran the nozzle check/clean head MULTIPLE times. It took maybe 8 or 9x each for the printer to work again.
Lesson that was learned is to use the printer every once in a while to prevent ink clogging or drying.
It’s an expensive lesson because running the nozzle check and cleaning the heads that many times use A LOT of ink. So I suspect if this option doesn’t work for you it will likely be because you ran out of ink.
If you have enough spare ink, just keep at it. The printer will work again.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
This seems to be the general consensus. It seems like the printer shouldnt \need that but OTOH it was only about $100. =/
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Usually this means that the printerhead is clogged or it is dryed because of empty catridges. I have managed to bring epson’s back to life with simple syringe tool using cleaning fluid. There should be a paper towel at between the printerhead and bottom of printer to get the cleaning fluid so there is no mess left after cleaning printerhead. It is also important to avoid extra mess because there is a reader “eye” at printerhead somewhere which tells where the printerhead is situated.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I too have the same problem I have cleaned the printer head numerous times no results are the same - no print, Is it worth the cost to replace the printer head or toss it out?
You should google something "Epson HP Canon Kodak Printer nozzle unblocker 200ml Print Head cleaning Kit" these are very useful tools (a "must" for epson ink printer owner)
댓글 달기
It won’t print. Brand new ink in it and The paper loads and comes out with no problem
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have an Epson WF2750 and I love it. My original problem was the black would not print even though I put in a new cartridge. I did a search on google and they came up with printing using glossy setting on both the computer and printer. This did work however, it took a long time to print and my husband hated it. He wanted to buy a new printer. I did some more searches and found several Youtube videos on how to clean the print heads. Well I tried it and I have my old printer back. Everything works.
I used a solution of windex and rubbing alcohol, a syringe, and a 1 inch piece of tubing like for an aquarium tank. I followed the videos, turned off the machine heated the solution in the syringe and put it over the print head and injected the solution. I did it a couple of times (3) on each head until there was no more color coming out. I turned on the machine, loaded the ink, did a head cleaning and voila, it works. I am so proud of myself. I wasn't looking forward to getting a new printer just yet as I have a supply of ink that would have gone to waste.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Printer has set for a period of time and will not print. It looks like the jets are clogged. What can I do
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Nelson Ferguson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 6
7일 전: 27
30일 전: 72
전체 시간: 95,008
