주요 콘텐츠로 건너뛰기
Fix Your Stuff
Right to Repair
Parts & Tools
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3965 질문 전체 보기
Phone overheating when camera is on
Hi,
I have a problem with my iPhone 5s. I dropped my iPhone and the screen was cracked. After the drop, my rear camera and flashlight stopped working. I thought if I replace the screen, the camera might start working again but no luck. If I try to turn them on, the top right corner of the phone gets extremely hot and I need to turn my phone off to stop the heat.
Anyone know what might be the problem and how to resolve that?
Thank you.
K.V
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 2개
Sometimes on electronics the thermal paste can get dried up. Sometimes it's best to open it up, re-paste the thermal, and put it back together. Although what i think is happening is the camera is stuck on permanently and that is causing the heat ups. Hope that helps!
The camera part on ebay is about 10$.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Thanks for your reply. The flashlight is also not working. Do you think when I replace my rear camera, then it all should be OK?
의견 추가하세요
The camera and the flash light are correlated parts. If camera stops working, the flashlight doesn't work either. Therefore, fixing camera issue resolves the flash light. You can get the required part here. Check out similar vendors selling the same items at the most competitive price. This will benefit you.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Keiro Vantsi 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 1,163
