주요 콘텐츠로 건너뛰기
Cobra 29 LTD Classic. 2-way 40 channel CB radio. Features antenna warning indicator, SWR calibration, instant Channel 9, PA capability, dimmer control, switchable noise blanker and RF gain.
8 질문 전체 보기
Squelch has no white noise
I've got a used Cobra 29 that came with our used truck. The power comes on, but I cannot get any white noise with the squelch all the way to the left. Is that normal for these CBs? I also haven't heard anyone talking, so I'm wondering if it's working at all. Is there a way to test without another CB? Thanks, kevin
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
2개의 답변
Isn't the speaker damaged?
해당 답변은 도움이 되었습니까?
점수 0
댓글:
No. Sorry. I should have mentioned that the Weather is coming in fine. Just no white noise on the squelch in CB mode.
의 답변
의견 추가하세요
i am having this problem with my radio. i pullrd the antenna apart and cleaned the corrosion, and made sure the antenna had a clean ground. then i took the radio out and checked the connection on the cb.and found the coax is bad.because i could move it and get a little white noise... so i will be getting a new coax cable. hope this helps.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
klpiazz 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 32
전체 시간: 1,718
