trouble massage like Ubdate Firmware *Bios Mode*
my printer write a massage when i want to print an on the printer the massage says
Ubdate Firmware
*Bios Mode*
wait updating F/W
2010/10/28 Vo.01
Canon ImageRUNNER 2422 2420
좋은 질문 입니까?
Ubdate Firmware
*Bios Mode*
wait updating F/W
2010/10/28 Vo.01
좋은 질문 입니까?
ok then how can I solve this problem plse help how can I do " Ubdate Firmware
*Bios Mode*
wait updating F/W
2010/10/28 Vo.01
Canon ImageRUNNER 2422 2420"
해당 답변은 도움이 되었습니까?
Have u solved it? I have the same problem. Thanks
canon ir 2420 update firmware bios mode
*Bios Mode*
wait updating F/W
2010/10/28 Vo.01
해당 답변은 도움이 되었습니까?
this is all problem solution
해당 답변은 도움이 되었습니까?
*Bios Mode*
wait updating F/W
2010/10/28 Vo.01
Here is what you can do. That helped me once.
You need to get to mainboard and find there flash memory. In my case it was chip - 25Q64BVFIG. It contains firmware for that machine.
Then - need to desolder it, reprogram using programmer with support of that type of schemes and solder it to mainboard again.
Downbelow will be a link for dump to download (must mind you - that Canon iR-2420 was in Russia and I'm not sure about differences between US/Canada and European firmwares. Just to let you know that beforehand - that there might be some problems to show up. But I suppose - since machine will finish loading inner software and comes to ready state - you can just figure it out by playing with local/country settings). These are photos before and after (connector melts a little)
- About dump - it's ready to use with your programmer - it's been taken from newly installed machine (not by me - but from guys from similar Russian tech forum). DUMP for reflash memory chip
- About programmer - mine is - TL866A - pretty simple and cheap
Good luck! Hope that will works for you!
해당 답변은 도움이 되었습니까?
Here is link to forum Copytechnet - where I originally posted this recommendation
yep! what if i swap the chip with the one from 2318 ? will it work?
해당 답변은 도움이 되었습니까?
Not 100% sure, but suppose yeah, that might work for you.
hello i have machine canon ir 2420 , error message update firmware , i am change board usb , fix problem
해당 답변은 도움이 되었습니까?
That will work for sure! BUT will cost you a fortune! And yeah - that is much easier!
what would be the problem of this and what should i do ?
해당 답변은 도움이 되었습니까?
what would the problem of this and what should i do
Boa tarde a equipe da CANON, eu tenho uma maquina fotocopiadora canon 2420, ela tinha problema de fonte e ja foi resolvido, so que nao esta a fazer copia, aparece na tela a seguinte mensagem: Update Firmware * Bios Mode* 2010/10/28 VO.10W STARDR 5N
해당 답변은 도움이 되었습니까?
Como solucionar esse problema?
Please if any body knows the solution on how to fix this problem of (* bios mode * firm ware update ) on IR2420 Canon .
Please E mail me on vifeanacho@gmail.com
해당 답변은 도움이 되었습니까?
24 시간 전: 4
7일 전: 13
30일 전: 64
전체 시간: 8,096
1 Comment
Bertrand 의
