주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3979 질문 전체 보기
U2 IC Charge chip replacement! Please help!
Hello again ifixit.
Im just learning how to do BGA work and micro soldering and such. I had a quick question of replacing the U2 IC on an iPhone 5s, how do you go about lining up the new chip? It doesn't seem to want to sit correctly on the board connections, it keeps sliding to the side when I go to heat it up and if I put pressure on it, it immediately slips. Is there someone to clean up the board connections after removing the old chip? I had tried using desoldering wick to clean them up, but on a board i have tried that on before, it ended up pulling a couple of the connections away from the board. And I don't want to do that as it seems impossible to get solder to form another connection in those spots now.
I guess basically what I'm asking is, how does one clean up the U2 IC connections after removal of the old chip, and then how does one line up the new chip without crossing connections? It seems in most instructional videos, they skip the part where the clean it up.
Any help is greatly appreciated!
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
답변 2개
가장 유용한 답변
I have a complete U2 video that I'm editing now that details this. It will appear on the iPad rehab YT channel.
You use braid on the pads. And you let the chip align itself.
해당 답변은 도움이 되었습니까?
점수 2
댓글:
Please get that video up! There is no good english video about U2 replacement.
Align itself? That's interesting, but I can't seem to get that result. It always just slides to one side or turns slightly
If you get it close, it will align itself when you apply hot air. Try to keep your hot air source as perpendicular to the board as possible, and of course don't bring it in too fast or your chip will blow away and disappear into the 6th dimension.
So I assume I should use the lowest air speed setting? What temperature should the air be? I've been using 400F
It depends on your hot air system. Listen to the way the hot air whistles when it hits the board, that is a good indication of when you are starting to heat it up and solder it on.
Josh. It slides cos your air speed is too much. Adjust the minimum air pressure so you can easily solder that
의견 추가하세요
Use flux and quality solder wick. Make sure your equipment is getting hot enough and maintaining temperature. What size tip are you using? You will damage the pads on the board by either physically scratching them off or not using enough heat and pulling them off with the wick or chip. Don't remove the wick without keeping adequate heat on it.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
Josh White 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 2,870
