Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1540 질문 전체 보기
Why does my phone only go on apple logo
I have an iPhone 5s, and and a few months ago my apps started crashing but i thought it was because lack of space, and i can restart it and then it works again. Then just today, a few hours ago one of my apps crashed in middle of me using it and so i went to restart it, once i turned it off I pressed the power button to turn it back on and it only went to the apple logo screen for about 5-20 seconds then it turned off. I have been trying to turn it on but it keeps doing the same thing. It doesn't do anything once it is plugged into my computer or charging. No matter what I do it only goes to the apple logo screen then turns off. I can't update it, restore it or do anything. Is there a way to fix it? Or possibly get my pictures off of it. I have important pictures i can't loose.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글:
Has the phone been drop before? has someone previously worked on? Was the phone purchased new? are you using a original apple charger?
의 답변
@Sunny (I have no idea how to tag you)
It has been dropped before.It is cracked and during winter it has gotten wet so water may have gone through the cracks. I put it in rice over night whenever any water got on it. The phone is actually kinda new. I got it around November of 2014 and yes I am only using an apple charger for it. No work has been done on it, this is the first thing that has gone wrong with it.
의 답변
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
2개의 답변
선택된 해법
Hi hannah,
So judging from what you said, it seem like the phone is effected by liquid damage. liquid damage can be spontaneous, sometimes the effect doesn't show right away. So in something like this you should bring it to a shop and ask for a free diagnostic. but if you want to open it up and post some picture to see if i can find anything i can do that for you. let me know how it goes. if it helps please choose my answer.
Good luck!
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Hannah Dollens, for now I would suggest that start off by turning it off. Do not try to turn it on, to charge or to sync it. This could potentially make a bad situation worse since it could shorten more components on the logic board out. Disassemble your phone by using this guide. Clean your phone with 90%+ (or better) isopropyl alcohol. Use this guide to clean your phone. It was written for a 3G but all the steps are pertinent to your phone as well. Inspect your board for any missing or damaged components. Remove all the EMI shields to clean the board. Once properly cleaned, replace the battery and Lightning connector, then reassemble and re-evaluate. Water damage is the hardest to diagnose and to repair since almost any part can have failed.
iPhone 이미지
안내서
Repairing iPhone Liquid Damage
난이도:
어려움
1 - 2 hours
iPhone 5c Logic Board 이미지
안내서
iPhone 5c Logic Board Replacement
난이도:
보통
1 - 2 hours
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
Hannah Dollens 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 165
