주요 콘텐츠로 건너뛰기
Samsung Galaxy S4 모델 i9505는 13-megapixel 후면 카메라 및 5-inch 1080p 화면이 특징입니다.
525 질문 전체 보기
질문 마감됨
Why is touch not working on samsung galaxy s4 after I repair?
I use loca to put in a new screen on my s4 and after the touch was working on the screen normally then suddely it doent work anymore. Can anyone tell me why none of my button working right now. Back button and menu button . Help please
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
When you did the loca on the glass, did you remove the LCD and apply it to the glass, or did you leave the LCD in the frame? If you left it in the frame during the glass replacement, did you tape off all the areas where the loca is not supposed to go(top and bottom of LCD, over the top of the power button area, over the top of the LCD connector area)? If it was working after the replacement, and now its not, then it sounds like the loca has leaked into areas of the phone where it shouldn't. Try removing the phones rear housing and check for excess loca, especially on the LCD connector. If you find glue, disconnect everything and clean it with isopropyl(90% or better). The menu buttons may not be working for the same reason. This could all be due to damage from removing the glass as well. It is very easy to damage the LCD and the menu button flex during the process.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 603
