Can't surf Internet while I'm connected
My computer is old. I'm connected to internet, but I can't go any further with searching, can't sign in to yahoo, nothing. Says cannot display this page. I can get to the home pages but that's it. I messed with settings but I don't know what I'm doing
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
3개의 답변
선택된 해법
The best and easiest thing to do would be to backup all of your data, such as pictures and documents and reformat computer to factory state. This will reinstall all appropriate drivers and updates whilst eliminating all software related issues. You can also take it to reputable repair company and ask them to give you a quote for a repair. If it's not hardware related, should be fairly easy to repair.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
Hey Joanna,
Try following the steps here Change TCP/IP Settings incase you made changes that messed up your Network Adapter configuration. Also typically you're fine leaving the DNS part to automatic but you can always try changing them to use Google's DNS which are 8.8.8.8 and 8.8.4.4
Good luck!
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Thank you. Can u tell me how to do these things. ? Sounds nutz! I'm not good with computers:( you are very kind to help!! Thank you
의 답변
의견 추가하세요
hi Joanna,
Did you already tried this ? : https://www.cs.cmu.edu/~help/networking/...
it explains how to renew and release your IP.
good luck,
Kevin
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
joanna 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 59
