MacBook Pro video loss after running for a while
My video cuts out after a period of use - no backlight or picture. The interesting part is that the longer I leave it turned off, the longer it will have video the next time I try to use it.
I'm going to replace the thermal paste in case it's an overheating issue but if that doesn't work I'm assuming it's going to be a deeper, component level problem. Any ideas?
좋은 질문 입니까?
what do you mean your video cuts out like it you see artifacts or it freezing or the screen goes black , check your lvds connector be careful the next time it's gently press the connector on the motherboard with the machine on it's side to see if anything happens.
John 의
Yeah, screen just goes black, no image, no backlight. I'll check the connector, thanks.
Joshua 의
is it a 2010 macbook i5 sounds like gpu problem
John 의
Yep, it is that model.
Joshua 의
Do you have a disc that came with that mac if you do run the hardware chances are you going to get some kind of gpu failure that model is notorious for the gpu failure
John 의
1에 댓글 더 나타내기
