주요 콘텐츠로 건너뛰기
The 1998 version is based on the original Beetle but, in comparison with the old model of the vehicle, it is way more spacious and equipped with more advanced features.
Hi Beam headlights won't stay on, only flash?
Hi Everyone,
I have a VW New Beetle 2002 and replaced with new the Indicator/High Beam Stalk Switch as the old one was faulty and didn't lock in (when pushed back) for high beam light and hi beam lights didn't work.
Now high beam lights only flash when switch pulled forward but nothing happens when pushed back for hi-beam lights to stay permanently on?
Is it a relay or something else?
Any help would be appreciated.
Thanks,
Steve
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
put in a new bulb for the head light in vw bug 2010. daytime running light on passenger side works but not head light, high or low. can you help me please?
Hi Steve did you ever find a solution? Got the same issue here
댓글 달기
답변 1개
I would check the fuse if that's OK go for the relay swop it for another one if it works you then know, a lot of the relays can be swopped over !
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Wogboy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 3,643
