주요 콘텐츠로 건너뛰기
GSM version of the fourth generation of iPad released November 2, 2012. Model Number A1459 / 16, 32, or 64 GB
43 질문 전체 보기
질문 마감됨
ipad 4 is not charging
hi, i bought faulty ipad 4 gsm, it was not turning on and was not charging, so i heated its POWER MANAGEMENT ic and it starts up, but now problem is that it is not charging, i have replaced its charging port also, but it doesn't worked, while having closer look i observed that when it is connected its voltage regulator ic( Fairchild BCHAH/FDMC) is getting so hot and charger also gets hot.
plz see the image, the ic marked in black is getting hot.
i am thinking of changing pm ic, will it work???
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
and can any one tell me location of u2 ic on logic board???
댓글 달기
답변 1개
U2 chip is the square black chip right able the charging connector.
in your case i would replace what ever thats getting hot because thats most likely whats being shorted.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
can u upload any picture showing u2 ic, as m still unable to find it. or otherwise please tell the ic number of u2 ic so that i acn order it
u5900
please mark my answer as chosen if it helps and feel free to ask more questions.
good luck!
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,113
